RE: Genesis motor alignment issue!
Sure the motor can be moved back some, but you my need to remove a him from the pinion gears too. The only real way to tell is to see a pic of it, Think you can get a goodclear pic of the motor from the bottom and of the clutch setup? that would help alot!!
