RCU Forums - View Single Post - Another Elmod Question
Old 07-26-2008 | 01:16 PM
blitzkrieg65's Avatar
blitzkrieg65
Default RE: Another Elmod Question
ORIGINAL: Rebellion13
Hello All,
I have a couple of questions I hope someone could help me with. I have a HL Tiger that I want to do a full elmod conversion on, it has the metal gearbox but not the treads, although I will be upgrading those in the future. My question is which elmod system do I go with, I know I am going for the 6ch prop, but just wondering since I will be adding the metal tracks down the line. And my 2nd question is which transmitter is recommended? I have heard great things about the spektrum, although I have read the futaba is easier to set up. I am looking at either on of the 2.4ghz systems. I also have seen that ch5 and ch6 need a toggle or dial type switch, do these systems fit into that criteria? Since I am not familiar with either one of these. Thank you for all your help.
Wade
Hello Rebellion, I suspect you already e-mailed me, but here is an update, for the Prop 6 the Eclipse seven is the only radio I can recommend, you can use the Hitec Laser 6 but you only get 5 and 1/2 channels!
Correction the Futaba 7c 2.4 ghz will work with the Prop 6, one of my customers has confirmed this, but you need to be experinced with the adjustments of theses radios!
Yeah, the main gun and machine gun are on a three pos switch mg one way
cannon other with neutral being off. The airsoft gun still functions
too if I turn it on. Eng and lights are on a pot switch, you just have
to make sure all switchs are neutral before you turn anything on or you
wont get full travel
And it will work with the Prop version you get all the functions just on 4 channels instead of 6! So you can get everything you want with any 4 chanel radio!!!
The reason the Prop 6 does not work with the new 2.4 ghz is that is is setup and adjustments are digital and the guys in Germany designed the system for analog adjustments!
The Blitz
RCTandWars.com
