RCU Forums - View Single Post - Another Elmod Question
Old 07-26-2008 | 01:58 PM
blitzkrieg65's Avatar
blitzkrieg65
Default RE: Another Elmod Question
ORIGINAL: Rebellion13
Ahhh. So let me get this straight, takes me awhile lol. I could get the 2.4ghz but it will only work with the original prop version, not the prop 6 using the 4 channels instead? Or I could save a bunch of money and get the prop 4 and a simple 4ch radio to get the same results? And if this is correct which 4ch radio do you recommend? I only have used the radios that have come with RTR's for my rc trucks and tanks. . And yes I did email you before, but you see I am impatient and it is something I need to work on lol. Thanks again I appreciate it.
Hello Rebelllion I was corrected by one of my customers he has had success with a 2.4 gig radio the Futaba 7c with the PROP 6!!! Here is how he set it up...
The main gun and machine gun are on a three pos switch mg one way
cannon other with neutral being off. The airsoft gun still functions
too if I turn it on. Eng and lights are on a pot switch, you just have
to make sure all switchs are neutral before you turn anything on or you
wont get full travel
But you need to be very experienced with these radios, and allthough I do have an expert radio guy on staff we have nto had the chance to set this up ourself! I and using the Specktum Radio 2.4 gig in my EL MOD Matorro King Tiger and it and you can set it up with all the funtions unsing the first 4 channels or you can use the Futaba attack 4 channel or the other two radio that I have recommended, The Hitec Laster 4 will ork but it is a FM ground Frequency!
The Blitz
