RCU Forums - View Single Post - Mini Titan thread
Old 07-27-2008 | 12:37 AM
  #521
osterizer
Default RE: Mini Titan thread
ORIGINAL: noobflyer01
i agree with you Os. some of the parts on the mars kit is really puzzling. you shouldnt have to cut the ball links end to size. they should of made the short ones. i have build a total of 4 kits and none was as difficult and lenthy as the mars. hopefully they are aware of these issues and will improve or risk getting drowned in the sea of ever growing electric heli available today. Helis should be more of a performance bliss then just eye candy.
Noob, I'm sorry, but I doubt Gazaur will ever bring out another helicopter. They missed too many things with this one. It's great if you work through all the problems, but helis like the Titan don't have the issues the Gazaurs do and fly just as well. If you have an in with Gazaur, then forward my comments verbatim. Maybe Yu-yu will take note.
ok. now back to the subject of my darling mini titan....i'm trying to find the perfect blades for it. I'm going with the JGF 500Th 3380kv motor and plan on sticking the 13t with it. the motor draws 36 amps and i have the hobbywing 40a esc which would be perfect for the motor. Do the spacers they have for titan work well? this one....
http://www.readyheli.com/TTRPV0829_R.../ttrpv0829.htm
i dont think the stock blades are meant for 3d. i want to try the align blades but the blade grips are too big for the blades. i see alot of potential in my new heli. It was a joy to fly it today. i have a cheap key-tech gyro on the tail for it and it just plain sucks at holding the tail.
and one more thing... is there any tail servo bracket other then the cheap plastic ones from the stock? i would like a little metal so adjusting the servo placement on the boom a little easier.
The motor doesn't draw 36 amps. The spec means the motor will handle 36 amps without destructing, but how much it draws depends on how you load it. Put a 35A ESC and a 12T pinion on the 500TH and you'll be set.
