RE: Heli's are hard, I give up.
For reverse orientation (with the nose pointed toward you) I've adapted the "stick under the low wing" idea to helicopters. There's a giant imaginary joystick sitting under the heli that mimics the stick position on your transmitter. If the disk is tilted then move the stick to the low spot of the disk to prop it back up level again.
