RCU Forums - View Single Post - 55AX sensitive needle
Old 07-28-2008 | 09:48 AM
Bax
Default RE: 55AX sensitive needle
The needle could have a bad fit in its mounting tube, so that a slight wiggle will change the setting. You can tighten the needle a bit by using some teflon plumber's tape around the threads to eliminate some play.
