O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
55AX sensitive needle
Old 07-26-2008 | 11:53 PM
Default 55AX sensitive needle
I purchased my 55 AX new. I have not crashed,droped or damaged the engine (yet). I have always had a slight difficulty keeping a tune on the engine.
Today I noticed when I was tuning the engine that if i touch the needle valve with a very slight side pressure ( not turning ) it will change the engine tune.
Any ideas>
Old 07-28-2008 | 09:48 AM
Bax
Default RE: 55AX sensitive needle
The needle could have a bad fit in its mounting tube, so that a slight wiggle will change the setting. You can tighten the needle a bit by using some teflon plumber's tape around the threads to eliminate some play.
Old 07-28-2008 | 11:21 PM
I will give it a try.
Old 07-31-2008 | 09:53 AM
thesouth1's Avatar
I was tuning mine at the field the other day and noticed the same thing, I thought it was just me...
