ORIGINAL: friedclutch
191g on the battery? NO PORBLEM. My 2250 Lightning power 25C packs weigh in at 208g and launches are still very easy. Must make sure you place the battery into a location where the plane balances ok.
How did you balance your CG with the 208gr lipo?
Other question:
Because of the lipo weight the fan should be mounted on 4cm which i did.
When i mount the exhaust the transparent pipe is larger then the black exhaust (about 3 cm).
Can i cutoff the 3cm from the transparent pipe or should i leave it as it is?
