RCU Forums - View Single Post - CPP out of control!!!
Old 07-29-2008 | 09:32 AM
supermotoxaustin
Default RE: CPP out of control!!!
Well I did change the routing slightly because I have stopped using trainers and I used to have the antenna coiled around one leg of the trainer pod. I suppose I may have flipped to Idle up but I kind of doubt It because when I couldnt get the rotors to stop I went upside down so I would not lose It way up in the sky and If idle up was on it should have still gone up upside down with negative collective. Just incase can you tell me how the antenna should be routed and also with the controller facing you flat on the ground, should the idle up be switched away from your or towards you to turn it off?
,thanks for your replies
