RCU Forums - View Single Post - 9CAP Tx replacement needed HELP
Old 07-29-2008 | 09:40 AM
Bax
Default RE: 9CAP Tx replacement needed HELP
The 10C uses the same 72 MHz modules as the 9C. It does use a different 2.4 GHz FASST module, which will give you the 10 channels of operation. You can use all existing Futaba 72 MHz receivers with the 10C.
