RE: High idle problem
Make sure all your needles are set to factory settings including your idle needle. also apply carb sealant to carb rim as well as backplate area. based on what you said " I pushed the throttle link all the way in" makes me believe your idle pin is not extended far enough in your venturi area to stop it from completely closing thus you are shutting out all air entry into your engine.
