RCU Forums - View Single Post - Compatible wheels for tornado epx?
Old 07-29-2008 | 05:48 PM
tornbb
Default RE: Compatible wheels for tornado epx?
yeah you could do something like that. depending on the rim you can shave the inside lip off to narrow the wheel while maintaining the offset. i did that on some ae truck wheels so i could use them on the front. while doing nothing to the rear. the wheels only had the pin style. i took the hexes off and worked fine.if your not sure just browse tower. they give dimensions and most of the specs. thats what i did. i converted one of my buggies into a mt. so i had to find some wheels that would clear the front hubs. i just need to order a dif clutch bell to gear it down a bit more and ill be happy with that. hope the info helps youll figure it out good luck
