RCU Forums - View Single Post - need dogbone answer
Old 07-29-2008 | 09:26 PM
ehroof
Default RE: need dogbone answer
ORIGINAL: weeze
I searched some more and found out that i was also missing the front diff. dogbone and drive cup. The dogbone i found was the diff. one. So i'm still missing the front 88mm dogbone and the drive cup of my front diff. I know i can buy the dogbone but can i buy the drive cup too. Guess until i find or buy these parts i'll have a 2 wheel drive truck.
you need:
08060 dogbone from trans to front diff
08059 dogbone from diff to tire (front and rear)
02016 drive cupb (input cup)
***edit***
Also, its a good idea to put a sliver of fuel tubing in the drive cups to take up the extra slack of the dogbones, make sure there is a tiny bit of play so they dont bind but you will find this will stop them from falling out and eating the drive cups also. Make sure you put a little locktite on the grub scews on the drive cups and check them once in a while to make sure they are tight.
