need dogbone answer
Old 07-29-2008 | 07:41 PM
Default need dogbone answer
I lost the front left dogbone in my truck. When i found it and tried to put it back in it was too short. Is there another part that's missing ? The dog bone is 77mm manual says it should be 88mm.
Old 07-29-2008 | 07:50 PM
Default RE: need dogbone answer
What kinda truck first off? ... Oh waite you have the volcano sv right??? The volcanos have a solid dogbone. So you shouldnt be missing anything unless you broke it.
Old 07-29-2008 | 08:21 PM
I searched some more and found out that i was also missing the front diff. dogbone and drive cup. The dogbone i found was the diff. one. So i'm still missing the front 88mm dogbone and the drive cup of my front diff. I know i can buy the dogbone but can i buy the drive cup too. Guess until i find or buy these parts i'll have a 2 wheel drive truck.
Old 07-29-2008 | 08:28 PM
YEA YOU CAN BUY THEM TO http://allaboutfunhobbies.com/store/.../cPath/2_19_35
Old 07-29-2008 | 09:26 PM
ORIGINAL: weeze
you need:
08060 dogbone from trans to front diff
08059 dogbone from diff to tire (front and rear)
02016 drive cupb (input cup)
***edit***
Also, its a good idea to put a sliver of fuel tubing in the drive cups to take up the extra slack of the dogbones, make sure there is a tiny bit of play so they dont bind but you will find this will stop them from falling out and eating the drive cups also. Make sure you put a little locktite on the grub scews on the drive cups and check them once in a while to make sure they are tight.
Old 07-31-2008 | 08:06 PM
Thanks Eddie. THe good news is I found all the parts but once again lose the drive cup. Thought I had it loctited but guess it was not. I'm going to you site and make a list I'll e-mail it off to you for a quote.
Old 07-31-2008 | 09:18 PM
another good tip that helps is paint your dogbones and axles a bright color it helps if or when they fall out mine are bright flourestent orange . plus it looks kinda kool
Old 08-01-2008 | 04:39 PM
Redharris's Avatar
Yes...You can buy all those parts......
Himotoracingusa.com.....
