ORIGINAL: salerno
how do you detirmine if bracket has slipped? i checked the bracket and there were no old screw indentation where it was tightened on from factory, is there a way to check where it should be? what degree are they set from factory?
Hi Andrew
On every sensor I have removed there is a slight mark/indentation in the plastic from the flat washer heads of the screws that hold the sensor in place.
As a starting point, I find looking down at the sensor the edge of the plastic sensor bracket is ~ 0.5mm (from memory) from the centreline on crankcase. I will double check that measurement and email you.
Hope that helps with a starting point. Let me know how you get on tonight.
Cheers
Scott.
EDIT - Typo on oreintation of motor/sensor
