ORIGINAL: chuck l
How do you check the timing on these engines, and what should the timing be?
The instructions for the RCXCEL Igniton have a degree wheel you can print out to use, and a description on how to check for TDC etc.
28-30 degree max at TDC
You can download manual from RCCDI website
http://www.rccdi.com/ or we also have available at
http://www.dlenginesaustralia.com/do...ignitionv2.pdf
Cheers
Scott.
