RE: CPP out of control!!!
ok, thanks again for your response. I thought I may try pulling the main gear off and testing it to see if it does it again. I may have had bad batteries, I replaced them. I think I will try what you said with the antenna too cause I have tubes for my trucks antenna. Also how do you remove the crystals from the stock cp pro radio and 3in1?
