RCU Forums - View Single Post - Multiplex Gemini bipe CG?
Old 07-30-2008 | 02:33 PM
MRCRTR
Default RE: Multiplex Gemini bipe CG?
Hello;
I had a problem with the second flight of my Gemini last week. It took off smoothly, and then it started to roll over and over to the right. I cut back on the power, and the plane went face first into the dirt. When I checked the damage, it seemed like the right aileron was disconnected from the servo at the connection from the wing. The rest of the plane was damaged pretty badly. The battery was ejected through the front intake, and the rest of the nose seems slightly twisted. I have just now started to look at how to repair it because I was so saddened by the crash. I thought all the connections were tight, so I am not sure if the right wing connection was disconnected before or after. Does anybody have any ideas on how to fix?
Thank You
Mike C.
MRCRTR
