RE: jet-1a air valve help
Helijet, can you not get those replaced by the supplier, they are obviously faulty, mine hold the air from one weekend until the next.
JGwright, have you tried connecting the gear lines to the opposite valve as a test? You describe exactly the problem I had at first.
The gear would cycle once on power up. I knew it was only a matter of time before I forgot and she would drop on her belly and damage the finish. Also, try a power up with the gear switch in the other position (gear up) and watch the red light.
