RCU Forums - View Single Post - Compatible wheels for tornado epx?
Old 07-30-2008 | 06:07 PM
Matthew007
Default RE: Compatible wheels for tornado epx?
I took of my rear rims and put them on the front to see and the inner lip does rub against the plastics that hold the wheel hub and steering thingy. I don't want to shave anything off because what will hold the tire securely on the inside?
I wish I could go with rustler rims and proline 3.6" truck tires all around but im afraid it will rub on the front. Also I need all rears all around because front 2WD rims have no pins or hubs to hold the pins?
OK it seems RC10B44 have great offset for the front but these hex are 12MM I hope right? Couldn't find exact specs for it.
The specs say 32mm wide front and 40mm wide rears for the 2.2" on the redcat tornados, but the front AE rims say 27mm, with the wheels should add 5mm right?
I hope these work.
ID:	1000937   Click image for larger version
