RE: Extra 330lx set-up
Hello Kevin,
Thanks for the info.
The 5645's flew the plane just fine for 5 years ago,....I agree the 5955's or 7955's will serve the application better and I can reduce the amount of servos in the tail. I am guessing the K&S 1090's will be around $500-$600 with everything. I will order the gear from JTEC and the tubes from Troy Built.
I would like to see some photos of where you have things arranged internally and the pipe mounting application you used. Are you flying yours on 2.4Ghz? Glad to hear Gerald N. is still flying,...haven't seen those guys in a long time.
Thanks for the great support!
Bill Holsten
