RCU Forums - View Single Post - Overloading an engine
Old 08-01-2008 | 11:25 AM
gkamysz's Avatar
gkamysz
My Feedback: (19)
Default RE: Overloading an engine
A glow engine ignition timing is related to glow plug, compression ratio, and mixture. As RPM drops with everything else the same there is more between ignition and when the engine reaches TDC. If too much of the mixture burns before TDC the engine gets very hot. Ignition point can be delayed by richening the mixture, reducing compression ratio, or installing a colder plug, or a combination thereof.
