RCU Forums - View Single Post - Controller Jumper placement?
Old 08-01-2008 | 05:44 PM
punkindrublik's Avatar
punkindrublik
Default RE: Controller Jumper placement?
Actually, you only want one to use one jumper. The "Br." is the "brake" setting. So you need to choose one setting with the type of battery and the brake setting you want.
If you want the prop to spin freely at idle, you want LiXX-Br. OFF
If you want the prop to stop turning at idle, you want LiXX-Br. ON
Brian
