RE: Byron Wedell Williams Racer Build
Marty,
Welcome aboard and thanks for the kind words.
Will try to catch up on posting. BIG lag in hunting and waiting for parts to make the Horizontal stab flying wires.
The servo tray is served up in two pieces that are epoxied to the formers. The forward tip is then fiberglassed to the fuse top and bottom. Next you add 1/8x 1/4x 6in spruce strips to double where you are mounting the servos. Barely got all the clamps set. The rear engine former is set and as per prior post the styrene tube placed it just a hair off. It is not an issue the mounting tube fits fine. The rear former was tack glued then set with Aeropoxy. I was able to get into the void where the fuse skin and the former didn't meet flush so it solid. View from the rear looks great.
Pete
