RCU Forums - View Single Post - Byron Wedell Williams Racer Build
Old 08-01-2008 | 07:28 PM
  #69
Rocketman612's Avatar
Rocketman612
My Feedback: (85)
Default RE: Byron Wedell Williams Racer Build
Took a step back and worked on the pass through for the wing flying wires. Started by cutting the 4 styrene tubes then with scrap balsa left over from sheeting fashioned top and bottom plates to stabilize the tubes but also to anchor the covering around the tube later. Small pieces of balsa were used against the ribs to attach to. Everything got sanded to shape and I'm pleased with the results. This setup should look near scale to the original plane and be a fast setup at the field.
Pete
ID:	1002131   Click image for larger version
ID:	1002132   Click image for larger version
ID:	1002133   Click image for larger version
ID:	1002134   Click image for larger version
ID:	1002135   Click image for larger version
ID:	1002136   Click image for larger version
ID:	1002137   Click image for larger version
ID:	1002139   Click image for larger version
