Ryan STA Kit by SIG - I need advice!
siggemann on the wing struts I just put a wire in one end and made a plate on the wing and the other end is screwed to the fuse. Installing the strut after the wings are mounted. On the insterment panel I copied what is in the plans except on each side of the panel I installed a toggel switch one for the reciever and the other for the nicad. Also is one of those LED battery level lights on the insterment panel. This works out quite well for me and my ST Ryan. Also donot use the plastic that they supply for the hinges instead use a set of Robart pin hindges. They will last a long time plus they are easier to install. I'm now in the prossess of converting to the Robart hindges. Also add the appropriate amount of wood for the hindges to be properly installed. I think you will like the way the plane handles affter you get off the ground.
