Ryan STA Kit by SIG - I need advice!
Bish,
Great looking plane!!! I hope mine comes out as nice. As you can see from my posts, this is my first big project. I had build smaller control line stuff when I was a kid as well as some rubber band flyers. Nothing on this scale though so the help I am receiving is truly appreciated. I am in the process of making the modifications as directed by nchrome. It is good to hear that the wires are not needed as I did not want to mess with them at the flying field. A question I have about the flaps is did you get the full 35% deflection? Also do you use a flap/elevator offset when the flaps are deployed? If so how much of an offset do you use or should I say what would be a good starting point in setting that up? Did you use plastic or cloth for covering?
