RCU Forums - View Single Post - O Ring Damper missing(?) and one torn
Old 08-01-2008 | 09:14 PM
dooleyje
Default RE: O Ring Damper missing(?) and one torn
ORIGINAL: badazzgti03
hell yeah true bloods are the ****!! got those for my chopper and they rock!!! well worth the $$
Yep they are good damper and I also use them. As a note your stock dampers will last a lot longer if you grease them witn lithium grease and keep them that way. Your nitro helis also should have been greased. On my SEv2 I still have the stock o rings with well over 50 flights. No need to change if everything is working. Thats the only way I can get a set of dampers to last more than 10 flights. I do like the bloods the best.
Jim
