Flight Box
I wasn't sure where to post this so i thought I would start here.
I have a field box that i have made and put on a radio flyer wagon to tote around at the airport. I Just bought a new wagon from lowes that has peumatic tires and made a lot stronger and larger as well. i want to improve on my original two designs before, however my question is do you guys have any suggestions or have some of your own that you've designed. I currently have two power panels on oppisite sides of the wagon(front and back) and don't like the one on the front because the handle gets in the way, works good for a chalk every now and then but not that reliable.
Well hope someone has done this before and has some pointers or some great ideas
a few things i am thinking of doing is putting a 2 gallon plastic gas tank in for the nitro and using it for two different power panels and i think im going to mount them on the sides instead of the front and back. I want two because my brother also flys out of the same wagon and it makes it a lot easier to start two at once and stay out of each others way. I will use a deep cycle 12 volt battery as well. I also want to integrate a way I can put my transmitters in there I'll need 3 slots for my 9c one for my brothers and the other for my 10c i'm planning on getting.
The current box has the top completly flat that doubles as a work bench as well, so i think i want to continue this theme as well with the newer and improved one.
I have a dc field charger for the rx and tx batts as well. and want a place to store my tools and accesories as well.
