RCU Forums - View Single Post - Another how do I fix this thread
Old 08-02-2008 | 09:16 PM
ChuckW's Avatar
ChuckW
Default RE: Another how do I fix this thread
ORIGINAL: gaRCfield
On the elevator, the halves were lined up properly and became bent after a crash. I will look and see if when I bent the elevator I softened up the hole where the cross bar enters (maybe just inject glue into the hole?).
Are the halves loose on the wire connecting them? I've repaired a problem like that by carving away the balsa on one side and exposing the the wire inside the elevator. I flooded the area with epoxy, put a piece of balsa in to replace what I carve out, sanded everything smooth and patched the covering. It worked pretty good.
