RCU Forums - View Single Post - Great Planes Lear Jet crashed plans needed
Old 08-04-2008 | 04:29 AM
Props4ever
Default Great Planes Lear Jet crashed plans needed
One of the fellow flier crashed my new Lear jet today. I didn't do CG check on it yet and told him repeatedly not to fly it but he thought it was ok and started to do long high speed runs across the runway. On one of the runs plane bounced off the runway as RT LG broke, stalled towards left, did 3 cart wheel rolls before coming to rest. Engine is OS 46 SF, prop was APC 10x8 but wasn't producing enough power to fly this model.
Weird thing about all this is, that he is very experienced model pilot, and have been flying at this flying field for over 10 years now, yet this all happened!!
Fuse is busted open from right side from firewall to back of wing saddle, formers are badly damaged, cowl is cracked, servo tray is damaged at back.
Wing sustained most damage as it got damaged from 3 areas, main lower right spar is damaged from wing root, right forward wing mounting dowel attachment on LE is broken off, root rib is cracked, another rib besides it is broken, rt LG block is broken, outer left tip tank is punctured from 2 spots, right tip tank is cracked open...
Now i need its plans and instruction manual from someone who wouldn't mind helping me out with rebuild of this bird. Let me know. Thanks
ID:	1004014   Click image for larger version
ID:	1004015   Click image for larger version
ID:	1004016   Click image for larger version
ID:	1004017   Click image for larger version
ID:	1004018   Click image for larger version
