RE: Another how do I fix this thread
Make sure you won't need the remove the rudder to fix the vertical stab. It would suck to fix the rudder only to need to remove it a few days later. If you need to remove those hinges the best way is to use a Dremel cutting wheel and cut them in half. Then sand them flush to the surface and mount another right next to the old one.
