RE: O.S. 46FS piston ring
Basically, you just have to be careful when installing the ring. Set it on top of the piston, and then gently start at one side of the ring gap and work your way around, sliding the ring over the edge and onto the side of the piston. Then gently work it down into the groove. Make sure the ring gap is lined-up with the pin.
