O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
O.S. 46FS piston ring
Old 07-31-2008 | 06:21 AM
Default O.S. 46FS piston ring
While replacing bearings on my .46SF, I managed to break the piston ring. A new ring is on order and I would appreciate any tips on how to avoid breaking the new one during the replacement process.
DaveB
Old 08-04-2008 | 09:58 AM
Bax
Default RE: O.S. 46FS piston ring
Basically, you just have to be careful when installing the ring. Set it on top of the piston, and then gently start at one side of the ring gap and work your way around, sliding the ring over the edge and onto the side of the piston. Then gently work it down into the groove. Make sure the ring gap is lined-up with the pin.
Old 08-06-2008 | 04:51 PM
Bax,
Followed your advice. The ring was installed without a hitch.
DaveB
