RE: Engine Tuning
OK GUYS, I screwed up this time!!! I went out yesterday to fly and had a great morning got off the ground fine and made my first perfect landing, and as I have said earlier I feel the plane is under powered. I made some adjustments and then i moved a screw I should not have moved and had no power at all. I loosened the screw that holds the throttle rotation device in place. From reading I guess as long as I have a 1mm opening at the low end and wide open at the top end I am ok is this right? Once again any advice would be nice. I do appreciate it Mike.[&o]
