Convert to floats
I have also just soldered a brass tube on the front cross bar and then take off the nose wheel and slide the gear mount into the tube. a wheel collar and your done. You have to put a spacer under the tube to make clearance for the collar. Make sure you disconnect the steering arm !!!
