RCU Forums - View Single Post - How Do I Remove Glued In Wing Joiner?
Old 08-05-2008 | 06:52 PM
B.L.E.'s Avatar
B.L.E.
Default RE: How Do I Remove Glued In Wing Joiner?
If it was glued with epoxy, you can use a heat gun to heat the joint. At around 400~450 degrees, epoxy turns into goo and lets go. I have removed a "oops" firewall glued in with epoxy that way. Patience, it takes awhile to get the joint hot.
