RCU Forums - View Single Post - How Do I Remove Glued In Wing Joiner?
Old 08-06-2008 | 10:03 AM
JohnBuckner's Avatar
JohnBuckner
Default RE: How Do I Remove Glued In Wing Joiner?
ORIGINAL: beachbrada
I am I will end up buying more tools and supplies to fix it when it will probably be cheaper to just buy a new wing set.
No it will not be cheaper it will be very expensive in the long run and it even could cost you the hobby. Do not be just another crippled arf'er who can fly fine but can not even do the simplest of chores on his own airplane because he is afraid to try. People who do not make an efforrt to learn the building basics soon disappear from the hobby.
Like one poster so eloquiently stated: This is not rocket science. Its a very simple procedure and you have been presented a number of slightly different ways to proceed along with detailed photos, most will work just fine.
So dude you need to first:
Muster up some courage
Start your tool collection now, the tools will last for a thousand repairs or builds, a replacement wing will only last to the next crash!
Start building your lumber supplies: a little balsa and a little ply
You have plenty of both moral as well as tech support right here on the forum if you are not shy about posting.
I wish you well
John
