RE: Thunder Tiger 61
Sounds like your carb is sucking air at the attachment point Gene.
Try loosening the carb, then press it down against the O-Ring as you re-tighten it.
If it IS leaking air at that junction, this should correct it - of course now that it is no longer sucking extra air, you will probably need to adjust the needle valve to compensate.
