RCU Forums - View Single Post - Does the OS 46 LA have...
Old 08-07-2008 | 12:54 PM
asmund
Default RE: Does the OS 46 LA have...
Like I said, if you have a very poorly manufactured engine then the gasket may be beneficial and you should use it. I have never had any use of a gasket between the muffler and the engine. The oil residue coming from a potentional leak from the muffler joint will be very minimal compared to what is coming from the exhaust outlet anyway, the engine will run fine anyhow
