RCU Forums - View Single Post - Replacing EZ-Start
Old 08-08-2008 | 09:42 AM
DaveG55's Avatar
DaveG55
Default RE: Replacing EZ-Start
Yes, that's it. Yes, that should be all you need. Yes, the engine will have to be removed to switch to a pull start.
Hope you know how to tune, otherwise you can expect some serious blisters between your fingers.
Be sure to carefully adjust the gear mesh between the clutch bell and spur gear when you reinstall the engine.
http://www.traxxas.com/support/kb_se...highlight=mesh
Good Luck
