RCU Forums - View Single Post - Mojo build
Thread: Mojo build
Old 08-08-2008 | 03:27 PM
Goinstraightup's Avatar
Goinstraightup
My Feedback: (26)
Default RE: Mojo build
You're going to love your Mojo!!! I bet you'll put the wing together once then never take it apart. Then you'll wish you didn't have the extra weight. I don't know what you have to haul it with tho'. If you have a really small vehicle, then you need the RW wing. Yes, the Mojo final assembly is tedious, but not that terrible. Just remember that rubber bands, bar clamps, blue tape and a square are your friends... Also, you can step it along to make it easier. Glue the front motor mount top to the fuse top and wing top one time. Then do the motor mount bottom and wing bottom to fuse bottom. Then go along and epoxy the tube to the rest of the fuse with a syringe. It's not bad when it's broken up into sections.
