RCU Forums - View Single Post - CPP with G110 TONS of questions.
Old 08-09-2008 | 01:59 AM
ebaysrt4
Default RE: CPP with G110 TONS of questions.
Hey just wanted to give everyone a update on this. I did everything like glenn stated and it worked. The problem was that the instructions say to put the g110 on reverse and my heli did not like that at all. I switched it over to standard and it fixed my issue with the heli spinning out of control. Here is what I ended up doing.
Set the gains on both the 3 in 1 and the g110 to all the way counter clockwise as well as leaving the 5th channel on the TX all the way down.
Switched the g110 from reverse to standard.
Adjusted the pot till the heli would get a good hover right from take off.
Turned the 5th channel on the TX up to about 85 percent with no issues with spinning.
After doing this the tail seems rock solid. I was using RRADS school of flight to learn how to fly this thing and had no problems keeping the heli hovering very stable in a 10x10 square. It would even hover one handed which I could never do before. Finally I do not regret purchasing the G110 Head locking Gyro. Thanks Glenn for all your help. Your advice helped me out TONS. I also just installed my superskids on it and other than being a major pain in the ass to figure out how to put it together I am very happy with. The heli feels like the chassie is alot stiffer now and no broken landing gear.
