RE: DL-50 engine
Hi switch26,
Do not remove the throttle spring, it keeps tension longitudinally on the throttle shaft, so you do not get excessive play. You can unhook it if your want. I left my alone, as the tension it puts on a standard servo arm, is not enough to make a difference to the servo.
Bound_4_Hell
Life should NOT be a trip to the grave with the idea of arriving safely in a well preserved body, but rather to skid in sideways, RC transmitter in one hand, a joint in the other, body thoroughly used up, totally worn out and screaming "WOO HOO what a ride".
