RE: DL-50 engine
When you run your engine without unhooking the throttle spring, do you use a pull, or a push pull rod?
I had heard that one of the well known flyers uses a pull Kevlar cable, instead of a rod.
Have any of you used this type of throttle pull setup?
What do you think?
Greg
