RE: Kingtech Jets
ATJ Turbines (translated)
ATJ Turbine China-made jet engines officially listed La ~ ~
Taiwan's manufacturing production has been the engine of La paste a few products and plans to fly abroad and share the Friends of sync with the current listing 10.5 KG, and 22 KG thrust engine listed in Figure
Excellent material than foreign manufacturers, we have all kinds of CNC machines and turbines balancing machines, electronic testing equipment logistics no problem ~
10.5KG specifications
Full-length: 295 mm
Diameter: 111 mm
Idle: 33,000 RPM
High-speed: 123,000 RPM
Exhaust temperature: 560 ° C - 660 ° C
Compression ratio: 2.2: 1
Thrust: 10.5kg / max RPM
Engine weight: 1.45KG-starter with the ECU, engine -
Fuel: Jet A1, JP4, kerosene
5% jet engine oil
22KG engine
Specifications
Domestic
ATJ-220
22KG specifications
Full-length: 350 mm
Diameter: 131 mm
Idle: 30,000 RPM
High-speed: 108,000 RPM
Exhaust temperature: 680 ° C - 750 ° C
Compression ratio: 3: 1
Thrust: 22.5kg / max RPM
Engine weight: 2.45KG-starter with the ECU, engine -
Fuel: Jet
A1, JP4, adding 5 percent for kerosene jet engine oil
Fuel Consumption: 640g / pm
(Full thrust 22.5 KG)
