RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 08-10-2008 | 03:56 PM
  #2494
switch26
Default RE: DL-50 engine
Hi switch26,
I mounted the ignition module and battery on a foam base and rubber bands. (See Photos) Gas engine tend to vibrate a lot more that glow. You will need to check everything after a good days flying, as screws, bolts, nuts, set screws, etc… will come loose.
You will also need to keep all ignition components, including battery and ignition switches 10 inches away from the receiver, servos and Rx battery. 10 inches will assure you do not get glitches in your control electronics.
I also used a High Tech Blue Aluminium Servo Arm on the throttle, as the one that comes with the Walbro Carb is useless.
Here is a signature that suits my situation.
Bound_4_hell
My wife said that if I go flying one more time she'll take off….….
It’s been five years and I still do not miss her……….
Very nice setup Bud,do you have to change the rubber bands quite often?looks like a vibration free setup,i'll see what i can come up with,that would be a better signature than mine,LOL
by the way i'll be running spektrum so i dont think i'll have any glitches with it but i am still going to mount the bateries,switches and servos as far as i can for peace of mind,oh yea i forgot to ask is it important to have an engine cut off module?i see alot of advertisement about them
