RCU Forums - View Single Post - Qhor problems
Thread: Qhor problems
Old 05-18-2003 | 10:34 PM
tileflyer
My Feedback: (9)
Default Qhor problems
I have my ailerons setup as far as the servo travel.I have the pushrods in the outter most hole on the servo arm.On the aileron contol horns the clevis is in the bottom hole.Make sure your ailerons are set neutral with the fuse.Yes the Qhor roll rate is pretty slow,but if you stiffen the wing up a bit it improves a little.
