Problem Programming JR SX600
Hello,
I am trying to program a JR SX600 so that both aileron Servos function on their own (Flaperon Option). On the plane I plugged one Hitec HS65MG into channel 2 and the other Hitec HS65MG into channel 6. I am using a Berg 7 receiver in the plane. I can set the sub-Trims of each servo just fine. When I go to set the Travel Adjustment there is no response from the servo plugged into Channel 2 and when I change the Travel Adjustment on channel 6 it changes it for both ailerons.
I thought that with the flaperon option that all functions were available for both channels and that I could set the low and high travel on both ailerons individually. Does anyone know what I am doing wrong, or can anyone direct me to where I could find information on programming the JR SX600. I have the manual and all it states is that you should have all function on both ailerons. Do I have someting connected wrong? Will the radio not allow for the setup of independant ailerons?
