RCU Forums - View Single Post - Kingtech Jets
Old 08-11-2008 | 09:23 AM
tony5548's Avatar
tony5548
Default RE: Kingtech Jets
ORIGINAL: monkeyking
It seems that they plan to introduce them in August-September.
I found this info:
- It seems that they are doing their own R&D and that they have high tech
- Model name: K-70X
- At present for jet engines for the test version
Diameter: 95 mm length (including the starter motor): 255 mm
133000rpm → thrust 6 KG
140000rpm → thrust 7 KG
- "Now Taiwan's own production of high-tech low-cost engines coming soon"
Kingtech Jet and ATJ Turbines is completely different from the company.
Kingtech Jet K-70X is the new design, patented the jet engine, high-tech factory production, Taiwan's defense industry companies.
full length:255mm
Diameter:96mm
Idle:48000rpm
High-speed:145000rpm
Temperature:650 ° C
Compression ratio:3.2:1
Thrust:7.5kg-32 ° C
Fuel: for Diesel & Jet A1, kerosene.
I heard the news in Taiwan,Kingtech Jet K-70X prices is between $ 1650 . $ 1950. U.S.D.
